jsinpa
So I'm in the market looking for a grapple as I have some land clearing to do at my friends house. Basically, I'll be clearing out the brush: jagger bushes, leaves, etc and also take out trees that are down along with some dead ones that need dropped. Plus, I want to be able to use it on other applications, like demolition or what not. Just look for the most versatile one for my needs.
I've researched and looked at so many, my question is, which out of these two grapples I've found, which would be more suited for what I am doing. The rock grapple has replaceable teeth plus the jaw opening is greater and tines are spaced at 4 7/8" apart. My thought was with the teeth The root grapple has the curve to it with the serrated end and the tine spacing at like 8 7/8" and opening at 39"...The gentleman told me the rake is the more popular model of the two. I've also been told its better to go with the two separated claws verses one that runs the full length because of picking odd shaped items..They both retail for the same price at $2400 plus shipping...And I was told the steel is 572 steel, which I think the guy meant a572 whom I was talking too.
Also, I was told by one manufacturer that the ROC does come into play with this stuff..meaning if the attachment weighs in at lets say 800lbs and your rated at 2000lbs, then you'd be left with being able to lift 1200lbs of logs or whatever. Is that correct?
here are the two grapples I was looking at:
http://www.solesbeesequipment.com/skid_steer_rock_grapple.php
http://www.solesbeesequipment.com/skid_steer_grapple_rakes.php
