Gradall Carnage
Discussion in 'Forklifts/Telehandlers' started by 544D10, Dec 15, 2007.
  1. 544D10
    544D10 Well-Known Member
    Sep 8, 2004
    166
    Lucas & Mercier Construction Co.
    Oceanside, CA
    This is the rear steer ram cylinder where it connects to the spindle. It actually should connect at the rear of the spidle arm behind the center bearing with the messed up circlip.
  2. Xcopterdoc
    Xcopterdoc Active Member
    Apr 6, 2007
    41
    NC
    Did 3 of those last year. What happens is the tapered pin gets loose in the spindle and starts to rock. Then it shears off the threaded part on top and when the cylinder gets loose it breaks off the top of the pin that slides thru the cylinder bearing. One I worked on sheared off the bracket that holds the hyd lines to the drive motor. Wiped out a couple lines. Had to replace two of the spindles due to excessive wear in the taper. Wouldnt hold the pin correctly. Not a fun job!
  3. Speedpup
    Speedpup Senior Member
    Jul 7, 2007
    1,214
    President and all else that needs done!
    New York
    How does Gradall steering hold up if taken care of? What do you look at when buying used Gradall in the rear? THanks.
  4. activeorpassive
    activeorpassive Well-Known Member
    Feb 9, 2007
    70
    Electrical/Electronics Instructor for Big Yellow (
    Illinois
    Just spray some of that mass air flow sensor cleaner on it. It'll be good as new.:D
  5. 544D10
    Sep 8, 2004
    166
    Oceanside, CA
    I've been driving these for over 6 years and have only seen this happen once. I have seen the the center bearing weld break away from the axle on top also.
