John17three
So, having some hiccups with the lift again. This time fuel related (I think).
Within the last 6 mos, I noticed while triggering the boom function at idle, the lift would die. Thought that was odd. Never done that before. I’d start it back up. Going forward, I just applied more gas.
Well, just in the last few weeks, I noticed that every once in a while, for no reason at idle, the engine would rev up, then back to idle.
Well, last week the frequency picked up. After getting a gable wall of my log home suspended on the side of the house, I shut it off. This time it would not restart. Turned over, but nothing. Then I realized it had been a minute since I put fuel in it. It was down to about 2.5” in the tank. So my neighbor came over after adding 10gallons.
He showed me the lift pump on the side, but it didn’t act like it did anything. No tension on the toggle arm. He took a few of the hoses off, checked for fuel coming through the line. He also cracked open one of the metal lines. Not sure what he was doing. Nothing work. Then he pressurized the fuel tank somehow with air. That didn’t work. We were at a loss what to try next. So then I decided to try some ether to see if it would kick off that way. Turns out it fired up!! Sweet! It idled as long as we needed it to finish the afternoon work (30 minutes maybe). I shut it off, then started it back up. All was well.
It sat a week.
I fired it up this afternoon and immediately actuated the boom. It died. Would turn over, but wouldn’t kick off. Then I sprayed some ether, fired up. Figured I was gonna get another experience like last week, but on my way across the pasture with the lift (to hang treestands with it), it started revving high again. Under full throttle it with the engine revs, this thing just frigging took off. well, that was short lived. I went through two small roller hills and I left off the gas to check a low tire real quick, and it died. This time, ether wouldn’t work.
Here are some unknowns: did the 10gallons fuel bring it to the standpipe and all I have is a fuel level problem? (I’m skeptical i used 10gallons idling for 30 minutes, but I suppose if that barely brought it to acceptable level, that could be the problem)
Or is that lift pump causing an issue?
I’m gonna replace that lift pump ($25 online), probably replace the fuel filters too.
Any other things I should consider?
Model: 534C-6
Engine: Cummins 4B39-C
Engine Serial: 45266866
It sat a week.
Model: 534C-6
