Good thing or bad thing?
Cheap "old" Geezer
Cummins uses a Unit Injector, when they leak they smoke and miss pretty bad as at rest are Bottomed out plunger to barrel.
funwithfuel
Will county Illinois
Mechanic
I've had dripping injectors before usually accompanied by a horrendous fuel knock but again I've never had to replace a piston as a result if the piston did fail it was almost always the Crown that's why that image was so surprising to me. I appreciate everyone Sharing their experiences
Cheap "old" Geezer
That 335 that burned down made that piston look a lot less a problem!! It scored 1/3 the radius of the piston skirt as it went!!
td25c
indiana
All good valid points & questions .
Piston oiler nozzles look good .
No funky spray pattern on top of the piston crown .
Keep in mind this is a 290 Cummins big cam 1 . Turbo but no aftercooler .
Not that uncommon to see them " Flame " down the piston skirt .
I'm guessing piston ring failure got it started .
Number 4 failed and # 6 was not far behind it .
Going with rebuilt injectors and keeping the old heads .
This is what happens when ya keep a truck around to long ….. Ya get to work on it once in awhile . LOL !:D
td25c
indiana
Rebuilt injectors were $ 40.00 a piece .
Also went with a rebuilt turbo at $ 595 .00
Hate to spend that kind of cash on the project . But ya got to do what ya got to do .:)
