Doug Woolson
involuntary steering,when stepping on the safety pedal machine wants to intermiddently turn the wheels to left or ccw,it is getting a voltage signal at the steering solenoids,of varying volts,we replaced the joystick and problem persists seems to be difective alc500 circuit board,i can pull the two blue wires from duetz connecter at platform (36&37)wire at box on ground panel when machine acts up can see voltage at terminal on circuit board respective conn. for steering wires 36&37.wondering if any one else has run into this problem i,m running out of ideas what to check.thanks
