Genie TMZ 34/19 Error Code "0000"
NW PA
I came across some posts of TMZ owners that you helped out. I'm at my whit's end and am ready to hurt something.....LOL.
I sure would appreciate some of your knowledge.
The machine is a TMZ34/19. S/N T3401-328. Electric Sch #ES0209 VIN #5D8AA19171R000328
Batteries were replaced last year. (2) motor controllers in the last 3 years which I believe was due to bad batteries.
The control boards are the original green boards.
The lift gets used very little and sits for weeks at a time in my driveway.
It was acting really bad before I changed the batteries last year. The new batteries seemed to fix the controller issues until a few days ago. The ground controls work perfectly for the time being. The basket controls are intermittent at best. Might work for a few seconds and then quit. The basket will not work at all. If I extend the basket from the ground control and then switch the key to basket control, the basket will immediately retract without pushing the down button. The other jib cylinders stay in place when the key is switched.
All functions seem to work perfectly from the ground control. Basket controls are the problem.
My machine doesn't have the error display. You mentioned that you had a computer program. Any chance it's still available?
I will be more than happy to compensate your time.
Best Regards,
Chuck Castiglione
310 Mercer Rd.
Greenville, PA. 16125
cjcastiglione@Verizon.net
724-813-2102
NW PA
I did some checking this morning and found the following:
1. All of the ground controls work perfectly.
2. None of the platform controls work.
3.with Ground Control active: I can hear the basket solenoid click as each of the buttons are pressed. All buttons except rotation.
4. Platform Control Active: The platform solenoid clicks for all buttons except the "Down Basket" and rotation buttons.
5. If the basket is raised with the ground control, it will immediately drop if the key is switched to "Platform".
I tried to plug the platform touchpad ribbon connector into the ground control pc board but the ground control ribbon plug has more connector pins so I didn't push them together.
With the platform touchpad ribbon connector unplugged, I used my ohm meter to look for continuity of any two of the ribbon wires and all combinations were infinity.
Regards,
Chuck
NW PA
I broke down and bought the BLUE BOARD's. The installation took about an hour. The only wiring was to connect the new four wire harness to the key switch.
When I plugged in the main battery connector the pump motor began running but the lift didn't move. Both E-Stops were pushed in and the key was off.
I unplugged it immediately then checked all connections and found nothing wrong. Plugged it back in ,the motor began running, and unplugged it.
About 5 seconds later the "one year old" DC motor controller blew up like an M80 going off.
After some trouble shooting I found that the motor controller was shorted through it to battery ground.
The ground control of the lift worked perfectly 5 minutes before I began installing the new blue boards.
I'm not sure what caused the controller to short out, but it must have happened when I plugged the battery in the first time.
I disconnected the wires from the B+ terminal and taped them up so they wouldn't ground out.
Then I plugged the battery in. I pulled both E-Stops and as soon as I turned the key on the horn began beeping, on and off for about 20 seconds and then stopped.
There are two green LED's on the pc board. The E-STOP LED was ON. The OUTRIGGER LED was OFF.
I hit the ESTOP to shut it down. Then turned the unit back on. I did this a few times and the unit never beeped.
The jib boom was raised about a foot from when I ran the unit before changing the boards. I tried to lower it and it worked fine.
Connected VOM to the #1 wire to DC controller and the voltage was correct when I pressed the buttons.
Same for the #3 wire.
I found nothing wrong with any wiring or plugs. All wires are insulated and in good shape.
As of now, I cannot find anything that was out of place.
Just ordered (GN-160431) a new DC controller with a contactor kit that GENIE recently began installing.
It's a relay that disconnects the battery from the B+ terminal on the motor controller.
It looks like the #1 wire "ENABLE" 24V signal is used to pull the relay in.
They say that it will keep the controller from catching fire or blowing up.
We'll see....
The controller and contactor will be here in a few days and hopefully everything works.
NW PA
I installed the new contactor and all of the new cables. The directions were written well. The contactor is a essentially a heavy duty relay that connects the battery to the DC controller every time a button is pressed and then disconnects the battery when the button is released. My guess is that the DC controllers will last much longer since they only see power when a button is pressed. Let's hope so. Only issue was (1) wire that was originally connected from (P1 Pin 1) to the B+ terminal on the controller. This wire needs to be connected to constant battery voltage, not the contactor. I connected it to the 175 amp fuse. The lift works great and it only cost me about $2500 and some time. I bought everything through www.gciron.com. Frank helped me out as best as he could. Anyone know of a company that buys sets of green boards? The new boards were built in by York Products in York, PA. I would think that some enterprising sparky would figure out how to repair the green boards and resell them. Maybe someday......
scottwj
Houston
New problem with my TMZ34/19. I have previous posts in this thread with machine info.
Using my machine today OK. left it set up, after lunch it quit working.
No lights or display at lower panel.
Checked power at all Troubleshooting Chart 1 locations. Got 25v at:
1)both E-stops both sides,
2)key switch in platform and ground positions
3)both sides of circuit breaker
Have removed main power, let sit and reconnected with no change.
E-Stop green LED is on, on main board (goes off when either E-Stop activated)
Boards are blue BTW.
Anything like a shorted input or output that could keep the main board from booting up?
If its a bad board, any way to identify the problem board without buying and swapping,
hoping for the best?
Thanks,
Scott
DanaT
Wayne, Nebraska
I have TMZ-34/19 with similar issue but don't have LED readout (G8 Diagnostic Display). Outriggers down and locked, all lights solid green, batteries show full charge, have 24 volts. Newer motor controller, doesn't appear to be bad. Went up, then back down, now nothing, can't retract outriggers, can't move boom. Is software available to use computer to help diagnose?
Bertfish
Darlington, MD
I need that software too if its available. Just put new circuit boards in mine and I now have error code 0100. Guess what, that doesn't appear in any of the manuals!
Bertfish
Darlington, MD
If your unit has a serial port for diagnostics this should apply to you.
Genie tech that I talked to pointed me to this link (ftp://ftp.genieindustries.com/Chris H/) and said to download TMZ Monitor.exe. He also said that you must connect to the unit serial-to-serial from a computer; it will not recognize a serial-to-USB adapter. Apparently this program allows you to watch what the processor sees as you press buttons on the unit so you can compare input versus what the processor sees/tries to do. I did not try to use it yet so thats about all I can offer.
aballworth
iowa
Can I get the program.
do you have access to a laptop with a 9-pin serial port or a USB to Serial Adaptor?
At the lower control box on the bottom is a connector to interface with a computer.
Message me an e-mail address and I will get the program to you for your laptop. This will assist you in troubleshooting your communication error.
I would imagine that the Genie service tech asked if the boards at the upper and lower controls were the same color? Green or Blue? They must be the same. Also, are the DIP Switches on the cpu board set in the correct positions?
IS there any way I could get the program? I am having the same problem. My email is aballworth@gmail.com
DARTHESE
US
genie 34/19 pc software.
HI, I was wondering if you still have the software for the laptop. If so, may you email it to me at darthsally@gmail.com
StonikM
CZ
Hello, I have the same problems, has anyone TMZ Monitor.exe and sent me a link PLS?
kaya1923
Germany
Hi forum members,
may i gently ask for the TMZMonitor.exe file, we have huge problems with a Genie TMZ50 with blue boards and it is not allowing us to extend outriggers, only downwards function do work.
Once we remove green (data-) wire from platforms control, the ground controls do work again.
I checked switch settings and setup according to manual docs.
Does anyone have schematics of the blue circuit boards itself?
SMD Q1 seems to be burnt, our genie Connector BD has printed pn starting with 7618 RevB but on google pics it is 76383
I changed the Q1 with same part from Platform Control donor board we have, and it is still not working burnt also donor smd transistor now
Mark_71
North Carolina
I recently bought a 2003 34/19 with hydraulic stabilizers. The machine has new batteries, a new #83046 blue CPU board, and a new motor controller. The CPU powers up normally with no error codes (----) and the horn works from both ground and platform controls but nothing else works. The booms are locked down and the stabilizers are fully retracted. I manually checked all 14 solenoids as good and the CPU does detect solenoid "open" condition and flags the error if I unplug any of them. Also all of the battery charge lights are all on but the beacon is not flashing (if I bypass the CPU and power up the beacon it works). I can see data activity on the 9 pin serial port with an oscilloscope but do not have a PC serial adapter to see what it is yet. It seems the processor is running fine but is "waiting" for some condition before enabling the pump to allow the stabilizers to come down (the pump motor controller is not getting enabled).
I have seen others with the same symptoms on this forum in the past. I have three questions:
1) Has anyone found the problem causing this behavior and solved it?
2) Does anyone have any info about that 9 pin data port and what info it reports?
3) Does anyone know where the "Negative Boom Angle Switch" is on a 34/19? I suspect the negative angle switch may not be working correctly.
Mark_71
North Carolina
OK, I see there is not much activity here (no response to my last post).
One more try. I found the Negative Boom Angle switch and it is working. The processor is running and detects the upper, lower, and jib boom retracted switches and will sound the chirp alarm it I trip the switches. The motor controller and pump motor are working when I bypass the control box and give the motor controller the 24v Enable signal combined with a +4v Speed signal. The data port is transmitting at 4800 baud and recognizes a serial to USB adapter by flashing one of the LEDs under the CPU board when I connect it, but I still can not see any data. The processor is running with no errors and is detecting things like the horn button, the boom retracted switches and the battery voltage but it seems to "waiting" for something. I have been holding down one of the "function enable" buttons several seconds and pressing "Extend Outriggers" with no response. I also checked the level sensor and it is reading about 2.5v on both the X and Y axis when the machine is level just like it is supposed to.
Does anyone have any info on that 9 pin Serial Data port? It would be very useful to see what events the processor is seeing!
M&JRepair
Illinois
Hello all. I've got a genie TMZ 50/30 that flashes code 0001 I've tried to use old posts on here to figure it out but the wiring diagrams and pin locations are different than the one I have. It is currently in the stored position ready to haul down the road. So when I turn the key on it beeps an the outrigger lights flash on the pad. I've checked the switches at the pads on the outriggers an they all appear to be operating correctly so I'm not sure where to go at this point the battery's are charged an have 24 volts
