Brian Emmerling
I have a 2006 genie S65 man lift with a deutz engine. s6006-13895. The unit will not operate up down extend and retract. I checked all the wiring everything is getting power. to confirm that the power is working I took the wires from the solenoids and put them on the jib coils. the jib responded perfectly. I am leaning towards the flow control valves that are activated when you hit the function controls. But I highly doubt both solenoids would go out for both the up,down and extend retract. the up/down has a wire that goes to a relay. The extend retract just goes from the switch to the solenoid. there is nothing else I can find that both circuits go to at the same place. So i dont know how the two are effected by the same issue.
Thanks for taking the time to read.
