Betamike
serial S6008-17282
Hey everyone, first post here. Im an apprentice tech that got thrown into this issue on a Genie lol having no luck figuring it out so far.
Machine will drive fine while switched on high speed (level ground). Once you turn the switch to low speed (incline) the Steer Axle wheels start to lock up when trying to move. In high idle it’ll start to stall the machine and you can hear a clunking. On low idle it’ll crawl but the Steer Axle again will clunk and drag.
Drive motor is putting out 290 PSI and at when checked at the traction manifold it is putting out 260 psi. No codes on ALC board. Brake and 2 speed valves have power. Measured around 11V not exactly 12V.
Weird thing is, in the platform with the switch planes removed, if I grab a section of harness and have my foot on the pedal the machine will start to drive foward and Steer right. I’ve checked every wire for damage or breaks and everything looks fine.
Real lost.
Real lost.
