Same here - a 2001 JLG600AJ LRG425 EFI with no start - no fuel pressure at rail - pump runs for 2 seconds and then power shuts off to pump - timing light shows spark when cranking so the crankshaft position sensor is working. Before no start, engine suddenly became hard starting, would start but belch blacksmoke and run not on all cylinders but then would clear up and run fine. If restarted would restart and run fine. If left sit, would be hard starting, and now, no start. Fuel pump does pump fuel and fuel does return to tank for 2 seconds so fuel pump and relay should be good. Replaced main three connector fuel pressure regulator, but now thinking maybe fuel pump or something else (2ndry fuel pressure regulator as fingered above or maybe timing belt slipped)
Thanks in advance for any ideas!
