Genie S-85 XC ( Engine Warning 7-21)
Discussion in 'Forklifts/Telehandlers' started by Jose Angel, Nov 3, 2021.
  1. Jose Angel
    Jose Angel Member
    Nov 3, 2021
    5
    Brownsville
    Genie S-85XC doesn't crank , it has an engine warning ( 7-21 ), supposedly man lift will function as normal. Service and repair manual solution is check the engine fault code with and engine scan tool.
    I will appreciate any help
  2. Jose Angel
    Jose Angel Member
    Nov 3, 2021
    5
    Brownsville
    Someone knows what engine scan tools is used for diagnosis Genie S-85 XC with a engine Deutz TD 2.9 L4 ?
  3. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    Not sure what you'd need to pull codes. So your ground control display won't show actual codes?
    So something is triggering the machine to not start. Low oil level? Water in fuel bowl sensor?
    Have machine in on position, and jumper the starter solenoid to get her going if you're in a pinch?
    Jose Angel likes this.
  4. Jose Angel
    Jose Angel Member
    Nov 3, 2021
    5
    Brownsville
  5. Jose Angel
    Jose Angel Member
    Nov 3, 2021
    5
    Brownsville
    The ground control shows " engine warning 7-21" and the buzzer is beeping. The service manual says for that error the machine will work. When I remove both E-stop that alarm appear and the buzzer is beeping, with that condition I had try start ( ground or platform) and only noticed the fuel pump turn on
  6. Jose Angel
    Jose Angel Member
    Nov 3, 2021
    5
    Brownsville
    By the way I checked the coolant level sw, water in fuel sensor, probably I will need test all basic sensors. For that reason I'm trying to connect a engine scanner
  7. tool_king
    tool_king Senior Member
    Mar 29, 2010
    1,940
    road mechanic owner
    new jersey
    You will need deutz serdia software.
  8. Txhayseed
    Txhayseed Senior Member
    Dec 23, 2019
    451
    Texas
    As tool king said.. You need serdia to access deutz but you should be able to see all the info with the ground display module. Fault codes and the definitions as well as inputs from engine sensors all from the display.
