Genie GS 2668 RT Power to Panels
Discussion in 'Forklifts/Telehandlers' started by Aegishjalmur111, May 14, 2020.
  1. Aegishjalmur111
    Aegishjalmur111 New Member
    May 14, 2020
    1
    Oregon
    I apologize if this is the wrong forum - I didn't see one specific to scissor lifts so this seemed closest.
    I have a 2006 GS 2668 RT, and I'm having a problem where all of a sudden, I went to use it and I'm not getting power to either of the control panels. I checked the battery and all obvious wires, and nothing.
    The only thing I can think is that it rained, and rain could have gotten into the upper control panel. Using a trouble light, I'm not getting any power to the upper panel at all.
    I checked fuses, breakers, etc...
    If I move one of the connectors on the Emergency Stop 1 relay to the center, the lower control panel comes up with a ECU fault 02, or something along those lines. This usually refers to a disconnect between the upper and lower control panels, which is obviously the case since I'm not getting power to the upper panel, but I should still be getting power at the lower panel without jumping that relay..
    Any help is greatly appreciated.
  2. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Did you check the upper control cable connection? It's just under the deck.
    How about removing the bottom panel on the upper control to verify all wires are connected.
