Hello,
I am looking for some insight on a problem we are having with our scissor lift. When the joystick is activated to drive or lift it starts pulsating the motor and will not run smoothly. It only runs smooth when it is fully depressed in the full throttle position. We have swapped in a new motor controller as well as disconnecting the hydraulic pump from the motor. We put a new circuit board in the platform controller and tried out a new joystick with no luck. We have put all the original parts back on with no luck and we also have another genie lift that I have hooked the motor up to to check and see if it would gallop still and it did not.
serial # 48773
Any help would be appreciated
Thanks
serial # 48773
Thanks
