Genie 1930 electrical issues
Discussion in 'Forklifts/Telehandlers' started by gyman98, Sep 17, 2019.
  1. gyman98
    gyman98 Well-Known Member
    Aug 29, 2011
    54
    Saskatchewan
    I Agree that I don’t think it should be negative either, both little wires going to it are both ground as well according to my multimeter
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,221
    Oklahoma
    It is some type of relay with the white wire being the signal wire. It could be an primary ignition, hydraulic motor...………….follow the red wires and see where they go.
  3. skata
    skata Senior Member
    May 10, 2007
    695
    midwest
    You're reading ground through the motor I bet. Jumper that solenoid and I bet the hydraulic pump comes on. But I don't think that's your problem. I'd be looking at the charging circuit, because if you plug in the charger, the machine is disabled.
  4. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    They go to the motor controller
  5. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Sparks fly when I do that, short to ground.
    I don’t have those option wires hooked up that disable the machine when charging but I’ll still try and isolate the charger
  6. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Ok so I found some wires on the platform to main harness plug, fixed those now I get a 01 and a 02 code on the platform control. I tested continuity from the platform control right down to the ecm and all 5 wires tested fine.
    Ecm shot?
  7. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    319
    Somewhere
    Okay.... back probe the wires at the ecm connector B1&C1 they are a orange and a blue wire. You should get a reading of 60 ohms. If you get a reading of 120 then unplug the platform controller and ohm the same wires. If you get a reading of 120 ohms then your platform controller is good. If you get OL then it's bad. If the controller test good then unplug the ecm and perform a resistance check where wires B1&C1 plug in at the ecm. Again you should see 120 ohms. These are terminated resistors in the controller and ecm when both are good and the circuit is complete you will read 60 ohms resistance. Good luck to you and I hope that this will help.
  8. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Thanks! Hopefully I understood this correctly.
    I probed the back of the wires and I get 120ohm. I disconnected the platform and still 120. I unplug the ecm and test the 2 pins and get 120
  9. Paul Council
    Oct 12, 2018
    319
    Somewhere
    Okay with the ecm unplugged test the wires B1&C1 at the harness while the platform controller is plugged in. This will test the platform controller. You will want to see 120 ohms. if you get a reading of 120 ohms then your platform controller is good. If you got a reading of 120 ohms at the ecm then your ecm is good. if both the ecm and platform controller test good then you will need to recheck the harness from platform all the way down to the ecm. This is a canbus circuit any repairs like butt splices can screw it up. With everything plugged in and a good harness you will want to see 60 ohms.
  10. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    If I unplug the ecm and probe the wires I get OL, if I test the pins on the ecm I get 120ohms.
    Platform controller is NFG?
  11. Paul Council
    Oct 12, 2018
    319
    Somewhere
    Its looking like that's your problem. Now open up the platform controller and test the orange and blue wires at the circuit board. If you get ol then that's your problem. If you get 120 ohms then you have a problem in the harness somewhere.
  12. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I get 120ohm at the circuit board between the orange and blue wires but not at the harness where it plugs into the ecm.
    However my blue wire goes to A2 on the ecm harness and the orange to C1. If I test both those at the plug I get 120ohms
    On mine the black wire goes to B1
  13. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I’m very confused now. I have orange on C1 which seems to be correct. White on C2 which should be red. Black on B1 which should be blue. Blue on A2 which should be white.
  14. Paul Council
    Oct 12, 2018
    319
    Somewhere
    You are right. I looked at the schematics again and B1&C1 are black and orange. And will be black and orange at the platform controller. Run your test again. If you get 120 at the black and orange wires at platform your controller is good. With the ecm unplugged and the platform controller plugged in. Test B1&C1 if you don't get 120 ohms then the wires from that point to the platform are bad somewhere.
  15. Paul Council
    Oct 12, 2018
    319
    Somewhere
    I am thinking that the ecm pin out page is wrong.
  16. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Thanks for all your help. I really appreciate it! I get OL at the black and orange wires on the platform controller with the ecm unhooked.
    On the ecm I have 120ohm between c1 and B1
  17. Paul Council
    Oct 12, 2018
    319
    Somewhere
    Glad to help. Sounds like you found your problem.
  18. gyman98
    Aug 29, 2011
    54
    Saskatchewan
  19. Paul Council
    Oct 12, 2018
    319
    Somewhere
    You should be able to just get a circuit board.
    gyman98 likes this.
  20. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Perfect thanks again
