Genie 1930 electrical issues
Discussion in 'Forklifts/Telehandlers' started by gyman98, Sep 17, 2019.
  1. gyman98
    gyman98 Well-Known Member
    Aug 29, 2011
    54
    Saskatchewan
    I have a genie 1930 that was working fine and then lost all power. Nothing works now or lights up. I have 24volts through the fuse, I have 14 volts at the 7amp circuit breaker and the key. Zero voltage at the B+ and B- motor controller.
    I really don’t know what to check to narrow down where the issue is
  2. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    313
    Somewhere
    Check your estop buttons. Wires are known to come out. Also there at the motor controller there's a 200amp fuse.
  3. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    The e stop on the platform is good and has power both sides. I’ll check the control box button. The fuse at the batteries is good. I can’t find a fuse at the motor controller?
  4. Paul Council
    Oct 12, 2018
    313
    Somewhere
    That's the fuse that I am telling you about. I work on so many things that I get it all mixed up. :confused:
  5. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I hear ya, I checked the e stop on the platform control and it’s good too
  6. Paul Council
    Oct 12, 2018
    313
    Somewhere
    What is the serial number of your machine? I can help you better if I knew which 1930 you have.
  7. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I’ll have to look in the morning, only thing on my invoice is serial #98663
  8. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Is the charger plugged in?
  9. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Charger works, batteries are full, charger is unplugged and 24vdc is going through the main fuse
  10. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
  11. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Hi it is GS3009B098863
  12. gyman98
    Aug 29, 2011
    54
    Saskatchewan
  13. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I do not have power going through this black box where the 2 positive cables attach. Top has 25volts and the bottom has 1.5volts
  14. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Is that the relay that turns on the hydraulic pump?
    Do you have lights on the control? Hear any clicks when trying functions?
  15. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    I’m not sure what it is, my schematic doesn’t show it. I have nothing, no clicks, no lights
  16. gyman98
    Aug 29, 2011
    54
    Saskatchewan
    Correction, the top is positive and the bottom is negative. I don’t see why the bottom would be negative?
  17. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Bottom is red. I doubt it's negative
  18. Paul Council
    Oct 12, 2018
    313
    Somewhere
    I don't see it in the schematics either. If I had to guess that is a contactor relay. Basically when you power up with the key it makes contact and connects the batteries. It's kinda like a battery disconnect. One side should come from the battery and the other should go to the motor controller. That is probably where your problem is. Check all the wires on this contactor.
  19. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Or it is a solenoid for the hydraulic pump when you move the controls.
  20. Paul Council
    Oct 12, 2018
    313
    Somewhere
    Hard to know. I can only see two of the wires. And even if I can see the others I won't be able to tell where they are coming from. Genie is always leaving stuff out of the schematic.
