genie 1056 stalls
Discussion in 'Forklifts/Telehandlers' started by Greenmonzter, Mar 30, 2019.
Tags:
  1. Greenmonzter
    Greenmonzter Member
    Jan 7, 2017
    6
    carpenter/framing/ heavyequipment
    kansas city missouri
    I gotta gth-1056 10k forklift has a john deere 4045 engine..gets hot and shuts off. radiator is full, no coolant leaks.. no fluid on ground
  2. Numbfingers
    Numbfingers Well-Known Member
    Oct 28, 2016
    126
    mechanic
    Alaska
    Check the radiator fins on the fan side. Had one last year overheating because of all the crap caked onto the radiator fins. If you have an infrared temp gun you should verify it's actually getting hot enough to be shut down. Might be getting a false reading from the overtemp safety switch if it has one or the coolant temp sensor.
  3. Greenmonzter
    Greenmonzter Member
    Jan 7, 2017
    6
    I do have infrared temp gun.. what would the degree tolerance be?? between 180°~220°. I'm kinda new to the heavy equipment world. been wrenching my whole life, just not on a diesel engine. So i am open to all the information i can get
  4. MarshallPowerGen
    MarshallPowerGen Well-Known Member
    Nov 27, 2017
    54
    Diesel & Generator Mechanic
    Coeur d'Alene, Idaho
    How many hours on the machine? Idiot lights or temp gauge?
    Check the easy stuff first: Temp switch/sender function with a meter cold versus when it "overheats", (as above) temp difference at the radiator upper hose to lower, inspect and test your radiator cap.
    It's Genie, so the service manual should be available on their site.
  5. Numbfingers
    Oct 28, 2016
    126
    mechanic
    Alaska
    Like Marshall said, you can download the manual from Genie. The electrical schematics will be in there as well as the specs for the coolant temp sensor.
  6. Greenmonzter
    Greenmonzter Member
    Jan 7, 2017
    6
    its got 6155hrs... It is 2012 and it has a digital display on the dash that will display fault codes when ecm detects irregular engine conditions. I serviced the machine today and cleaned the radiator, they used it all day without it stalling. I took temp readings threw out the day also with the average temp 170°f and the highest being 200°f thats with a temp gun.. last week it shut down like 7 times in a day... the inner air filter was black..im sure it was well over due on service.
    MarshallPowerGen and Vetech63 like this.
