Gehl RS8-42 Parking brake not engaging
Discussion in 'Forklifts/Telehandlers' started by jake hollingsworth, Jan 12, 2018.
  1. jake hollingsworth
    jake hollingsworth New Member
    Jan 12, 2018
    3
    Southeast Iowa
    I've got our gehl in the shop for the parking brake not working from what I'm told. I have power to switch and sounds like power to the flow divider but it won't "grab" when i let go of brakes. any ideas? I've bled the brakes, filed the resivours and look at about everything. im not sure where solenoid is at either.
  2. icestationzebra
    icestationzebra Senior Member
    Jun 21, 2009
    300
    Not familiar with this machine but just about every off-road forklift has spring applied hydraulically released brakes. So if they don't grab there are only a couple things that could be wrong.
    Do the brakes work with the engine off? If so the valve is stuck open or on. If not it is something mechanical - pads worn out, springs broken, pads contaminated with an incompatible oil, splines stripped, etc. Drop the oil and see if there is any debris.
    ISZ
  3. jake hollingsworth
    Jan 12, 2018
    3
    Southeast Iowa
    the brakes work with the machine off and on, the parking brake is the only thing I'm having an issue with.
  4. icestationzebra
    Jun 21, 2009
    300
    I meant parking brake, should have been more specific. ISZ
  5. Hardline
    Hardline Senior Member
    Nov 29, 2009
    340
    Small business owner
    Waxahachie Texas
    Does the park brake work with the machine turned off?
  6. jake hollingsworth
    Jan 12, 2018
    3
    Southeast Iowa
    no, it doesn't work if it on or off.
