Curtis Book
I am working on a GEHL Rs8-42. The rear leveling cylinder was recently rebuilt with new seals. After installing we function tested and the leveling system is not working properly. After some checking, we found the lower (clevis side) of the cylinder is not getting any hydraulic fluid. Counter balance valves were all pulled and air released but still same issue. The top side is getting oil but not the bottom side. From the looks of the schematic, the bottom side is tied into the level cylinder on the front side of machine. Has anybody had this same issue or can point me in the right direction? Any help would be appreciated. Thank you
