Big update on this Galion, member here max mac got us a set of gears, and I finally have time to get them in the machine. I am wondering about a few issues I have found though, big one being the ring gear carrier flange is distorted, like a bent bicycle wheel. With the ring gear carries in the machine, I have 0.078" runout on the outer most part of the flange, 0.035" on the inner diameter of the flange, and .15" on the ring gear "hub" diameter.
Any ideas on how this bent/warped/moved? You can see the mating pattern on the old ring gear and the carrier flange too.
I am wondering if it would be a bad idea to face the ring gear carrier flange square in a lathe, and have a thick shim made go between the ring gear and its now thinner mounting flange.
