Galion 118C
matthew moore
Amelia Court House, VA
Can anyone give me information on the 6 cylinder Cummins engine that came in the galion 118C
6Ajeewp52QnKpRbg7
Pt1Pq4BWkjnCcfae8
moemontour
Pgh
Can you be more specific as to the engine information you are seeking? Cummins' online parts and information web site is called "QuickServe". Once registered you will need to enter your engine ESN# (XXXXXX) which should be stamped on a metal engine tag. If it is a valid ESN#, your specific engine data plate information should come up. You should also be able to view a small listing of engine parts and part numbers. The only problem being the parts are no longer available. If you want to replace your engine filters, look for a stamped part number on the filters. I was able to buy a new magnetic fuel valve from my local Cummins dealer. I was able to buy a new intermittent starter solenoid and filters from Napa.
