Mike L
I removed the failed transmission out of my truck and took it apart because I was curious and it’s not too bad. Front bearing in the counter shaft failed and the counter shaft dropped down which unmeshed the gears. I’m guessing that 5th gear is direct drive and that’s why it was the only gear I had. I’ve never rebuilt any truck transmissions but I’m gonna give this one a go. I’ve only got 2 damaged gears and one failed bearing. I ordered everything I think I need including all new bearings and seals. My question is what do I need to know to set up the bearing pre load on the 2 shafts? The rest of it is pretty self explanatory but I’ll take any tips you guys got.
