mekanik
I installed a clutch in a 2006 Freightliner M2 earlier this week. The truck has a C7 Cat and a Eaton 6 speed. The new clutch was ordered from the VIN. When I took the new clutch out of the box it was a 14" Eaton SOLO clutch. The one that came out was a regular clutch and was not original. The flywheel was resurfaced a new pilot bearing and release fork installed, the cross shaft bushings and shafts had no wear. The clutch linkage and related components were all in good condition with no wear. The motor mounts were good. I installed the clutch and transmission and followed the setup procedure for the clutch. When I cycled the clutch pedal a few times there was way too much free play. About 6" of free play. I adjusted the linkage to reduce the free play and cycled the pedal a few times and the clutch adjusted to have 6" of free play again. I kept adjusting and cycling the pedal until I ran out of adjustment on the linkage.
I never measured the release bearing travel but looking up at it with an assistant pushing the pedal I would say just over 3/4". A bit more that the .490" to .560" the instructions that came with the clutch call for.
There is a linkage on the firewall with one end connected to the clutch pedal and the other connects to the rod that goes to the lever on the bell-housing. I drilled a couple new holes in the lever on the firewall that connects to the rod from the bell-housing lever effectively shortening it and reducing the release bearing travel. It took me a couple tries but after drilling a hole for the linkage about 3" in from the factory one the clutch would adjust to 1 1/2" inches of free play.
I took the truck for a test drive and the clutch worked properly and stayed at 1 1/2" free play.
I'm puzzled why I would have to modify the linkage to make the clutch work. Considering it came from the factory with a SOLO clutch. I have installed a lot of clutches over the years but this was the first SOLO clutch.
