I started working on my old scraper yesterday...It's a 1979 Fiatallis 161, 16 yard machine....I bought it with a low hydraulic pressure problem....I started by removing the fluid from the 50 gallon reservoir....at the bottom of the tank in the strainer for the suction port, I found what looks like some sort of a hydraulic bypass assembly or pressure relief setup in 3 pieces, laying in the steel strainer....I removed all the access panels for the tank and got in there with a flashlight and looked over the entire inside of the tank....I can't for the life of me, pinpoint where these parts came from...I had a tank schematic faxed to me from a Fiatallis dealer and I don't see these parts on there either....Is it possible that these parts were carried into the tank from one of the hydraulic return lines? The guy that sold me the tractor says that it developed a pressure problem so he removed the pump and had it rebuilt then replaced it and the problem remained the same....hmmm....maybe these loose parts is the problem? I was quoted around 1200.00 to have this pump built....it's a vickers 2520 series, tandem vane pump (two pumps in one)....this sucker was a PIA to remove....I'd hate to put it back in without rebuilding it, but at the same time I'd hate to rebuild it for no reason....any advice from the hydraulic experts? I don't have a service manual but I ordered a complete set today....should be here in 2 or 3 days....here's some pics of the pump, the 3 pieces I found in the hydraulic tank and the tractor....
