CEwriter
Ford trumps GM power play with free engine-software update that takes 2011 Superduty Powerstroke to 400 horsepower and 800 pounds-feet of torque -- the new most-powerful diesel pickup over GM's 2011 Duramax
As seen at PickupTrucks.com:
Production of the updated engines with the new power ratings starts this week, but early adopters of the new 2011 F-Series Super Duty aren't being left behind because there are no changes to the engine or transmission.
“There are no physical hardware changes required,” Gryglak said. “The fueling schedule has changed along with transmission [shifting schedule] calibrations to make sure we have a smooth and continuous torque curve.”
Additional fuel injected during combustion is all that's needed to get the power bump.
Starting Aug. 31 and continuing for the next 12 months, 6.7 Power Stroke owners can have their engine control unit software updated for free at their local Ford dealer. The upgrade process is similar to a firmware update in a smart phone or PC and is expected to take about 30 minutes.
“Drivers are going to see most of the benefit in highway gears, fourth, fifth and sixth, in the amount of reserve torque that’s available,” said Chris Brewer, Ford F-Series Super Duty chief engineer. “If you're driving in hilly terrain towing a trailer, instead of a downshift happening sooner, it will happen later. You can stay in a given gear longer.”
Along with more power, 6.7 v2.0 owners should see improved fuel economy because the engine can shift gears faster and hold them longer. Ford says the engine will be 2 percent more efficient than 6.7 v1.0, making the 2011 F-Series Super Duty 6.7-liter Power Stroke diesel 20 percent more fuel efficient than the old 2010 6.4-liter Power Stroke V-8 model.
