Ford F-650 GCWR
Discussion in 'Trucks' started by Man with a plan, Aug 29, 2020.
  1. Man with a plan
    Man with a plan Member
    Jun 11, 2020
    20
    United States
    Would anyone have any idea what the GCWR is for a Ford F-650 with a 26000lb GVWR. Or even how the GCWR is calculated?
  2. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    5,272
    Andrews SC
    Medium and heavy trucks aren't like pickups, F-650 doesn't really tell you much. There are many different combinations of engine, transmission, rear axle, springs, brakes, frame rail profiles, and etc.
  3. Man with a plan
    Jun 11, 2020
    20
    United States
    Yes, I understand that. But there has to be a way for me to know how much the truck will tow. Am I legal if the power unit weight is under the 26000 GVWR with a trailer in tow and the trailer is within it's rated capacity?
  4. suladas
    suladas Senior Member
    Jun 30, 2016
    824
    In most places there is no legal limit as far as what you can tow, provided you don't exceed any tire, axle, or hitch, etc ratings. It's more what you should tow without destroying the truck. Depending how it's speced i'd say somewhere around 30k lbs.
    Spud_Monkey likes this.
  5. Hysert
    Hysert Well-Known Member
    Feb 6, 2017
    56
    Ontario
    Its usually determined by the tranny and axle ratio, i was recently looking at a KW T270 with a 31k GVWR, however it had a Allison 2500 and its GCWR was 36k.... ya same as a F550...
  6. redneckracin
    redneckracin Senior Member
    May 20, 2010
    479
    Civil Engineer
    Western PA
    I probably would not compare a f-650 to an international 4700, but I got my truck rated at 37,000lbs GCWR. I do have an Allison MD3060 transmission and a 3.73 rear end. 17k or 17.5k rear axle on 19.5 tires, DT530E and an exhaust brake. Although I do have juice brakes I have had 20k behind me and feel confident with that.
  7. Man with a plan
    Jun 11, 2020
    20
    United States
    Thanks for all the responses. Redneckracin answered the question I asked in another thread about possibly buying a Ford F-650 and the reliability and stopping power of hydraulic brakes on that size truck. So thanks for that response as well.
  8. Willie B
    Willie B Senior Member
    Jan 3, 2016
    1,995
    Electrician
    Mount Tabor VT
    I don't know how it is calculated. I can drive down the road with load on the trailer & say "I'm O K." Or "too much!"
    I've been asking the same question years now. Never had a response.
    I had a Chevrolet C65 1976 Tall Block 427, Eaton 5 speed, Eaton 2 speed rear differential. Never found a tow rating.
    It was equipped with a 30,000 LB hitch. My sons & extra sons routinely towed 20 tons. Never had an issue, only slow climbs up 15% grades.
