Ford 555D Hydraulic hose replacement
Discussion in 'Tractor/Loader/Backhoes' started by Setteduke, Jun 24, 2019.
  1. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    I am new to this forum, new to owning a backhoe and of course new to replacing hydraulic hoses. I have a 1996 Ford 555 that blew a hydraulic line for the stabilizer on the right side. Can you fellas recommend what wrenches/tools I need for getting these hoses off? The space is tight and I can't get a grip on the housing near the machine. Also, manual states i will need to replace the o rings, I am unable to find the size needed. Would these o rings be standard size? I knew that I would have some issues like this just want to have the right set of tools handy. I am in the process of clearing land for a future home and it's not close to any machine shops or stores. Thanks for all your help. Much appreciated!
    Tim
  2. Delmer
    Delmer Senior Member
    Jan 4, 2013
    5,548
    Usually standard wrenches work fine, if they're really tight then flare wrenches help. If the access is terrible, you might need to get crowfoot wrenches. Your best bet is going to be taking the old hose to a shop that can match up the fittings, Napa, etc. They should have the O rings for the fittings. You can use a kit of O rings, but it's not ideal.
  3. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    1,670
    s/e Heavy equipment operator
    Western Washington
    And sometimes you may need to bend or weld a wrench so it will get in the right place to work, another thing is to get a service manual for the machine you are working on as it will have invaluable time saving info for what you are doing... and usually list any special tools.
    thepumpguysc likes this.
  4. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    Thank you for the help. I am on a steep learning curve here. I figured out how to attach a few pictures. Once I get the busted hose out would you recommend pulling the ones close and replace them?
  5. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    I did purchase the serivce and operator manuals. They have the torque I need for each hose attachment. It didn’t give any specifics tools needed for this job.
    Thanks Again for the help!
  6. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    900
    North Carolina
    If you have O-ring fittings as in ORFS (Deere likes them) An o-ring kit specific to hydraulic fittings has saved me a few times... Instead of a trip to the dealer to get a new O-ring. Run of the mill O-rings are 70 durometer, ORFS rings are 90 durometer.
  7. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    2,438
    I'm not sure if all your fittings are going to have O-rings. Standard wrenches should get the fittings loose and just snug them tight. You don't have to reef them as tight as you can. Look at the other hoses to see what shape they are in before replacing them. The place that makes the hoses up should have the O-rings if you need them. Sometimes you need to remove covers and such to be able to get at the fittings or get a wrench on them. In extreme cases you have to take off a bunch of other hoses and parts off to get at the ones you need to replace.
  8. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    Welder Dave and hosspuller
    Here is what was in the manual. I will check to see if they have the O rings. They are ORFS according to the manual page. Thanks for the replies.
  9. Welder Dave
    Oct 12, 2014
    2,438
    The shop that makes the hose will have the O-rings for the fittings.
  10. jimg984
    jimg984 Senior Member
    Dec 2, 2009
    442
    ronda north carolina
    DON'T THINK YOU CAN FIND HOSE FITTING WITH ORINGS EASY, I HAD GO TO HOSE WITH FULL FLARE,, AND CHANGE THE ADPT THAT HOSE SCREWS ON TOO I GOT 555A FORD TBL
    YOU CAN PROBABLY BUY NEW FORD HOSE WITH ORINGS EXPENSIVE
  11. JD8875
    JD8875 Senior Member
    Apr 8, 2010
    309
    Harrisonville, Missouri
    Not sure about the 555D but my New Holland 555E has an Italian flat face fitting on most of the hoses. They look like a metric flat face fitting but according to my local hydraulic shop have a few oddities of their own.
    The best tools I have for hydraulic lines is wrenches from 6mm stubby, to 2 3/4", to include 12", 18", and 24" crescent wrenches and a 12" and 18" pipe wrench. Over the years they have all earned their place.
    John
  12. hosspuller
    Aug 28, 2014
    900
    North Carolina
    Yikes .. 24 inch ! Besides a flare nut wrench. how do you keep from distorting the fitting when it won't budge using a big wrench ?
  13. JD8875
    Apr 8, 2010
    309
    Usually that's for very large fittings. I had to replace the return line to the tank on my 555E. It was a metric male hose fitting that was bigger than anything I had in an end wrench. That big crescent wrench is also nice vecaube it's long and wide which allows it to be used somewhat like a small vise to split hoses apart. Just prop it up on it's back on the trailer deck and you can slide a hose fitting in it and break them down. It's also a terrible hammer and a knuckle buster if you let it jump.
    John
  14. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    Thank you for all the help. My crowfoot wrenches are too small, will return to get bigger sizes. Also, I must tell of my “dumb ass” move. The bolt that I was focused on went through the side of the tractor and had a nut on the other side. Yep, I was an idiot for that move. So got that puppy off and was a able to get the hose off the cylinder and now need to the the bigger crowfoot wrench and then should be good to go. Will update you once I get this all done.
  15. Billrog
    Billrog Senior Member
    Mar 27, 2016
    485
    band mill , backhoe and dump truck
    Armstrong, British Columbia
    I made my own larger crows ft wrenches for a couple bucks a piece from wrenches out of a pawn shop just heated up the end and bent them.
    jimg984 and DB2 like this.
  16. Setteduke
    Setteduke Member
    Jun 24, 2019
    8
    Clarence, NY
    I have changed three lines since you helped me with this question! made one custom wrench and found the right size crowfoot at local NAPA store. Thanks for the help.
