jimg984
I recently purchased this backhoe. It has a popping sound coming from the stableazers as they start touching the ground and rasing the backhoe. its coming from each side where the pins attach them to the frame. there is extra movement, i can't tell if the pins are broken or if the arms where the pins go thru have wear. there are no grease fitting in this erea, if these have wear enough to cause that much movement must not have bushing installed from the factory. all other pins and bushing have little wear. I need input on what maybe going on with this
thanks jimg984
Ronda, North Carolina
thanks jimg984
