Ford 555 loud engine
Discussion in 'Tractor/Loader/Backhoes' started by Clawed Backster, Dec 4, 2019.
  1. Clawed Backster
    Clawed Backster Well-Known Member
    Sep 19, 2009
    242
    Sunny Valley, OR
    The engine in my old 555 seems really loud to me. I don't mean exhaust noise, but diesel clatter or knock. It is the 3 cylinder. I haven't had the machine very long, and don't know much about its history, except for the fact that it doesn't seem to have gotten much maintenance. The oil pressure is good, but I don't know what a normal sound level for one of these engines is.
    Can anyone else with a 555 chime in as to what theirs is like in this regard?
  2. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    5,394
    Master Inj.Pump rebuilder
    Sunny South Carolina
    The Perkins 3 cyl. is very "clattery" for lack of a better term.
    It could be your injector spray patterns are outta wack.. THAT'LL make 1 loud..
    SO WONT pump to engine timing..{very loud}
    Look on the inj. pump mounting flange for the timing line.. its there..
    It will correspond to some degree marks on the engine block.. now go to your service manual to find out what its supposed to be.. OR..
    Take note at where it is NOW.. loosen the pump & turn it 1-2* on way or the other & LOCK IT BACK DOWN & start the engine.. DO NOT LOOSEN THE PUMP WHILE THE ENGINE IS RUNNING.!! or you'll end up w/ 2 halves of a pump..
    The timing on the pump to engine is 0*.. or dam close to the 0* line.
    Vetech63 likes this.
  3. Clawed Backster
    Sep 19, 2009
    242
    Sunny Valley, OR
    OK, thanks.
    Engine seems to run good, though it doesn't have much power. I think it is only rated at 65 gross hp when new, so I don't really expect it to be a powerhouse. No telling how many hours it has on it.
    I don't know a lot about diesel engines, but I would assume that pump timing would have a similar effect as ignition timing on a gas engine?
  4. jimg984
    jimg984 Senior Member
    Dec 2, 2009
    512
    ronda north carolina
    I have a 555A with the same engine in it,,It always had a rap noise noise with low rpms, had it checked 25 years ago at ford mechanic, hope it keeps rapping another 25 years,, mechanic said it just a natural sound on those engines, hope yours is the same thing
  5. Clawed Backster
    Sep 19, 2009
    242
    Sunny Valley, OR
    I drive a truck for a living, have been around diesel engines all of my life, and I have never been around one that makes this much racket. If it didn't have good oil pressure, I would be convinced that it is about to self destruct.
  6. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Our ford skip loader is the noisiest/clatteriest motor I have ever been around period!!! If I don't put in earplugs my ears will be ringing for a couple days after I run it :(
  7. Check Break
    Check Break Well-Known Member
    Jan 22, 2012
    247
    USA
    When you replaced the torque converter, did you use a high stall or a low stall. HS-s take a lot of rpm-s to make any motion. Ford 3cyl-s are very loud. That thing that looks like a muffler really isn't. There's a pipe at the bottom and a pipe at the top, both surrounded by a piece of sheet metal. No baffles. You'd have to make a video and post a link if you want an opinion based on your situation.
  8. berky
    berky Active Member
    Jan 10, 2017
    30
    Indiana
    Have owned 4 different Ford diesel backhoes over the years. They were all noisy. The design of the Ford motor is what I have been told by many is the culprit. Other than being obnoxious its just the nature of the beast.
  9. Clawed Backster
    Sep 19, 2009
    242
    Sunny Valley, OR
    It is a low stall converter, and I had thought about making a video, but sound is not always conveyed accurately on a video. Maybe I will make one this weekend.
  10. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,309
    Oklahoma
    Those are what I call odd fire engines. The design of them makes them noisy and there isn't anything you can do to correct it. If the engine runs smoothe at a high rpm and isn't doing the puffing of different colors of smoke, your good.
    Clawed Backster likes this.
  11. thepumpguysc
    Mar 18, 2010
    5,394
    U think the 3 cyl engine makes a bunch of racket..??
    Have u ever been a mile away from a Merc. Benz 5 cyl.??!!!
    Odd firing for sure..
    But like I said.. check the timing mark on the pump to the block.. if its a CAV DPA.. it;ll be 0*
