retired life
Have a ford 3 cylinder diesel tractor that think the pump plungers are stuck. Plenty of fuel to pump and metering valve not stuck. Worked good till parked for awhile. Started and run and then stopped. No fuel to injectors. Don't think shaft is broke because can take out bleeder plug and will pump out some fuel. Wondering if anything you can do before taking pump off or taking apart? Have injector lines disconnected at pump---no fuel coming out when turned over
