I'd bet not many on the other side of the pond have ever heard of Foden, much less seen one of their own-brand 2-stroke engines in action.....
Shifting instructions are a doddle. It's basically a 4-speed on the stick with a U-D-O air-shifted splitter on the steering column, hence 12 speeds. What he's doing is splitting gears between direct drive and overdrive for each shift. You can't split gears using low range while on the move. The problem with the 2-stroke engine is that there is pretty much no torque below 1500RPM and with the engine topping out at 2200 it needed a box that enabled the driver to keep the engine in the power band all the time. It gallops along nicely for a 50-year-old truck.Yeah, I'd love to see the shifting instructions. I thought I could drive anything, but that video left me dazed and confused.
The Foden was a conventional inline-6 in comparison to the Commer which was a 3 cylinder opposed-piston 2-stroke (that's a whole other story...). The TS was only 105BHP compared to the Foden's 175BHP, but the Foden achieved that from only 4.8 litres, although it was both supercharged & turbocharged (at least the last versions were).How did they compare to the Commer TS ? Were they as durable and did they have similar torque?
I’ve only seen videos of these motors, but I would like one for whatever may come along. They look pretty much EMP proof.
Fodens were famous for their LACK of power steering ............ but having driven one a few times I'd say on balance they probably didn't need it.Armstrong P/S I am well acquainted with and NO truck with Armstrong steers good unless rolling then they are not so bad.
