Foam Filled Tires
Discussion in 'Tractor/Loader/Backhoes' started by telwood, Aug 13, 2019.
  1. telwood
    telwood Well-Known Member
    Mar 20, 2013
    109
    GA
    I've been serious researching poly filling my tires for my farm tractor and front backhoe tires. Not a lot of info out there but seems it would work for me with constant tire patching during demolition.
    I don't see the downside of getting mine filled. Any thought on them?
  2. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    1,474
    s/e Heavy equipment operator
    Western Washington
    You'll lose some traction ability in bad soil conditions compared to air filled.
    Vetech63 likes this.
  3. Nige
    Nige Senior Member
    11,543
    What you also have to factor in is the cost of removing a foam-filled tyre from the rim when you eventually have to replace them. They have to be cut off and I would imagine there are only a limited number of places capable of doing the job. either way it will be an additional cost.
    Have you considered cushion tyres..?
    Ronsii, kshansen and Vetech63 like this.
  4. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    845
    Equipment operator,mechanic
    S E Pa
    The machines I have used with foam filled tires rode like a rock.
  5. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,646
    Oklahoma
    If you don't have back problems now...…..you will shortly after foam filling those tires. You better make sure you have a quality, spring/air seat in that cab. If you don't you better wear a hardhat while operating.;)
    mg2361 and Ronsii like this.
  6. mowingman
    mowingman Senior Member
    Jul 11, 2010
    419
    north Texas
    Heavy, expensive, and rides like a rock as mentioned. Don't do it. Just dump a big bucket of flat preventer slop in each tire before airing them up.
  7. kshansen
    kshansen Senior Member
    Mar 11, 2012
    6,921
    Central New York, USA
    No experience with the foam filled tires but at the quarry they decided to put a set of AirBoss tires on a Case 1845C, looked just like these:
    https://www.ebay.com/i/172852981146...MIxbjN7PX_4wIVlluGCh2R3wwJEAYYBSABEgJqlvD_BwE
    They did eliminate the flats but..... did a number on drive chains and axle bearings. Like people say about the foam filled the ride was very harsh to say the least. And then if you did damage a segment it sucked because you could not just bolt in a new one or it was like driving over a curb non-stop all day. Fortunately we did save the old rims and eventually put "normal" tires back on. And yes traction sucked with the airboss tires compared to pneumatic tires.
    Only reason I could see using the foam or Airboss tires would be if you were forced to run under conditions like a scrap metal yard or such.
  8. walkerv
    walkerv Senior Member
    Jan 22, 2016
    794
    wingate nc
    Try tire ject from what i seen it works good and isnt messy like other flat preventers.
    Bootheal and edgephoto like this.
  9. Nige
    Nige Senior Member
    11,543
  10. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,016
    Field Service Tech
    Alberta
    I hate foam filled tires. We must've had a bad run of them because they were ALWAYS flat spotting if parked too long. Its fun ripping down the road in 4th gear in the tele with flat spotted tires.
    kshansen likes this.
  11. Bls repair
    Jan 21, 2017
    845
    S E Pa
    Don’t have to worry about falling asleep behind the wheel :D
  12. kshansen
    Mar 11, 2012
    6,921
  13. CM1995
    CM1995 Super Moderator
    8,807
    Well I've got different advice for what it's worth.
    On the third set of front tires on the '03 420DIT and 2 of those sets were foam filled. The set that's on it now were put on a year or so ago. Just my $.20 but they work great. No front flats, ride is still a backhoe without ride control and wear seams normal.
    The machine was used around residential construction sites for it's first 6 years of life and the OEM set of tires were constantly picking up nails and getting flats. Foam filled the first replacement set and had good luck with it.
    Now the rear tires were replaced a few months ago and those are normal air filled tires with some snot in them.
  14. mowingman
    Jul 11, 2010
    419
    north Texas
    It has been reported on some of the lawn forums that the Tweels are terrible in mud. Many lawn companies have been buying mowers with these things. Again, the word is they are worthless in muddy conditions.
  15. edgephoto
    edgephoto Member
    Aug 14, 2019
    21
    Stafford, CT
    Thanks for the tip on TireJect. Never heard of it but the stuff looks like it would be handy to keep on hand. I may get a couple containers for my car too. Perfect for a trip for extra peace of mind.
  16. walkerv
    Jan 22, 2016
    794
    wingate nc
    Its pricey bit really seems to work , onelonlyfarmer on you tube has a vid from awhile ago , mounted a brand new tire for stackwagon i think it was and they shot it over and over again with buckshot.
  17. telwood
    Mar 20, 2013
    109
    GA
    Thanks for all the feedback. Ordered new air filled tires after getting a foam quote of 3 times the cost of new. I will look at the tireject for other equipment I have the same problem with.
