First machine advice for small property (5–20 acres?)
Status
Not open for further replies.
BeablossomR_
Hey everyone,
Just wanted to get some input from those with more experience.
If you were starting out with a small property (let’s say around 5–20 acres), what would be your first machine and why?
I’ve been looking at sub-compact vs compact tractors (around 20–40hp), especially ones with a loader, but I’m not sure if that’s the best route long term.
Main things I’d likely be doing:
  • light grading / driveway maintenance
  • moving dirt or gravel
  • basic property cleanup
  • maybe some mowing
Would you recommend going smaller and versatile, or jumping straight into something bigger?
Also curious any attachments you consider “must-have” right away?
Appreciate any advice.
30 to 50 HP tractor with a loader and 3pt. hitch. Don't get a tiny little toy tractor. (35-40HP would be ideal) Knowing your budget would help? You have dozens of choices of implements for the 3pt. hitch to do what you need done. If there's a lot of grass a mower for the back would be the first implement. If it's lawn get a finish mower. If it's rough with small saplings/light bush gets a single blade bush hog like mower. A flail mower is a great option but more expensive. If the driveway is in good shape a rear blade would be good to maintain it and clear snow. You could use a land plane too to keep it leveled if it's a long driveway. If you want to do more landscaping a box blade could maintain the driveway and do other jobs where you need to pull material where you want it. A box blade has a bigger learning curve though. The loader lets you dig material, clear and move snow and carry bulky items.
AMBMike
Southeast KS
Cat herder.
I'd go with a 30-50 hp tractor with a loader. Make sure it has at least one set of hydraulic remotes at the back, preferably two. If your budget allows you could also get a 3rd function hydraulic remote on the loader on case you want to add a hydraulic grapple at some point.
IMO a utility tractor like this is a good all around tool for a small property owner. You can do light digging, grading, snow clearing, and carrying duties with the loader. If your budget allows you can add a set of pallet forks and a grapple to add even more versatility.
Rear three point attachments are readily available and there's literally one (or several) for every need. For a small property I'd recommend a box blade and a brush hog/rotary cutter or finish mower for starters. Adding a hydraulic top link to the three point hitch will make that box blade do amazing things...
If you have heavy clearing, stump removal, etc is recommend either renting a proper machine or hiring that part out as it'll kill a small tractor.
I run heavy equipment for a living but evenings and weekends I play on my little property with a John Deere 1025R. It's really too small for what I do but even so it's handier than a shirt pocket. It has a loader with bucket and pallet forks, a mid mount mower that gets occasional use, and a box blade and brush hog for the three point hitch.
pdeal
West Virginia
My situation is similar. About 20 years ago i bought a Kubota L39. It’s about a 40 hp tractor with loader and backhoe. These are sold by the Kubota construction dealers not the Ag dealers. It comes with a 3pt hitch so the backhoe can be removed and hitch installed. It also has a skid steer type loader bucket that can be swapped for other stuff.
It’s about 7000 lb and the stoutest machine of its size i’ve seen.
I recommend one of these. Its been a terrific jack of all trades. I guess one of the things that makes it so nice over a compact track loader ( which i had and sold) or an excavator ( which i also have) is that it’s a fast mover. Transporting a bucket of stone or a grapple grab of brush, or something on pallet forks can be done very quickly.
And it has been very reliable. Zero issues in 20 years. Well, I guess maybe one issue, i just bought a new radiator for it because a tree fell on the hood of the machine and cracked the radiator neck. But i got online to a kubota dealer and click click and a new radiator is on the way, which came yesterday. So parts availability is good though not cheap.
Status
