Vigilant
- Joined
- Jan 8, 2011
- Messages
- 953
- Location
- Eastern NC
- Occupation
- Attitude Adjuster at the Graybar Hotel
Another vote for the KW T800, although I would not turn my nose up at a Pete. Compare the curb weight between the KW and Pete, and the turning radius. They should be close, but some of the competition, especially Mack, falls short in those areas.
Also, if weight is a factor, have a look at the KW T300, or whatever they call it now, and the Pete counterpart. If you will be an owner-operator, either one should hold up well for you. You should be able to easily pick up another thousand pounds of payload.
As for the body, I would be really sure as to what type of dump truck work you want to do. An aluminum body is great for crushed rock, but for hauling stumps and debris, for example, they won't last a good farting spell.
Before you go any further, I would take a good look at the types of dump truck available in your area, what it pays, and how many others will be competing for the work. If you go into this with the wrong truck and body specs, it could cost you dearly. Also, become very familiar with your state's weight laws, and how drop axles could help you, or hurt you.
Good luck to you.
Good luck to you.
