Polkchop
About a year back I picked up a RK55 (55hp Hydrostatic Cabbed tractor) which is basically a Mahindra. Long story short I purchased it with the intent to grade some driveways, and bush hog properties to make some side income. I ended up getting a contact who needs some help with new construction grading. The first job I attempted to work at I had issues with pulling a grade with my tractor with a box blade. The 3 point controls are super stiff, and near impossible to make fine adjustments in the height of the box. I put the tractor in the shop to see if the dealer could work out the kinks, but if not I may look into moving into a different machine. Does anyone have any tips to share to make grade work easier with a tractor? I currently have a hydraulic top link, however I will be adding a hydraulic side link to it as well for cutting swales. Also I have looked at Massey's, Kubota, and John Deere. Does one manufacturer have a significant advantage over the other? Are there any models of tractors that are better suited for grading than others? I appreciate any advice that you can spare.
