Galute
If you are washboarding it while finish grading you are taking too big of a bite. Lighten up. Try to keep the load the same the entire length of push. You start the push with an empty blade and then the more it loads the more it pulls down on it. You try to correct for the downward pull on the blade and the next thing you know you are riding the waves. Start out and pick up a light load and maintain that same load thru out the push by drifting onto what is already on grade. Remember its finish grade, you are not hogging dirt. Kinda like the arc the previous poster mentioned. Also when you do the rough in make sure you have just a little too much material so that the final grade is a light cut. It's much easier to finish grade with a light cut than it is to make a fill.
