ben46a
Reading this with interest..haven't been on here for awhile..been quite busy of late. I operate a 140 m cat grader with a trimble system. Now and then with the auto on both sides, the blade will jump..but I find this happens when there is less material on the blade. I also find this happens when you are going for example in second gear...just idling along. I find the higher you keep the rpm's the less bouncing\jumping the blade will do.
Now, I am leveling crushed gravel on the Trans Labrador Highway, doing the finish grade. I will level and trimble a section..I always leave a small windrow on the left side of the road after its all to grade...then I will tilt my moldboard all the way forward and brush this windrow from the left side to the right side of the road..this takes all the little washboards/etc that your auto had caused, leaving a smooth finish. Now I have question for you trimble experts...why do I leave the windrow on the left and bring it to the right instead of vice- versa?? Hint: my mast is mounted on the left hand side of the moldboard....lol
Workin for dexters now?
