Final Drive Housing leak -T190
Discussion in 'Skid Steers' started by mfiveash, Nov 14, 2021.
  1. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Hello,
    I found a pin hole leak from my final drive case housing on my Bobcat T190. It is leaking a remarkable amount from such a small hole. I removed the track and cleaned it up a little and when operating it starts pooling at the 9 o’clock side below the hydraulic lines.
    Obviously, I would rather not replace the final drive motor at the excessive price. I think replacing the case housing would lead to a lot of precision work and probably more problems.
    Is it possible and would you recommend for me to just spot weld over the pin hole leak? I would also change the drive oil and replace the case in line filters, but hoping I can just clean it up real good and bead a weld on it. Thoughts?
  2. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    It's hard to tell what I'm looking at in the pics. But if you say there's a pinhole leak in the casting, I'd say give it a shot with welding.
  3. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    I know, kind of a bad picture and was before it was cleaned up. I put UV dye in the hydraulic fluid to find it. The second picture shows where it is pooling. I attached another picture of the unit with an arrow where it has a hole.
  4. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    You going to mig or tig weld it?
  5. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Glad you asked. I actually only have a Miller stick welder. Have never used a mig or tig welder, so guess it has to be stick. Is that okay?
  6. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    Oof, I'm not sure about that. Hard to get a precise weld without over penetrating. If it's a pinhole leak, the metal there must not be that deep.
    I'd also sand that area and visually double check that it's just a pinhole leak.
    Simon C likes this.
  7. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Oh boy. That is bad news. Maybe I will hire a guy to do it. Would you recommend mig or tig. I don’t know anything about either.
    thanks for all your help!
  8. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    I think I know a guy who can mig weld it. Going to have to get it very clean though and will cost more than I like, but if it works then it will be worth it.
  9. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    I think tig weld is what will work best, and provide the most control while welding.
  10. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,738
    Service Manager
    Knoxville TN
    TIG is the best process for that, but the problem is going to be oil contaminating the weld area while attempting the weld repair. Not trying to dissuade from attempting the weld repair, only saying it may not work as hoped.
    melben likes this.
  11. Tones
    Tones Senior Member
    Mar 15, 2009
    2,105
    Ubique
    Have you checked the oil level in the planetary. If it's overfull then welding is counter-productive. The only cause for overfull hub is poor sealing between it and the hydraulic motor. In turn that can be caused by a worn motor which can be reconditioned. New hubs from the dealers can be a rip off
  12. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    That was a thought, but it seems it only oozes from that location when I start the bobcat and then comes out faster when I operate the final drive. I would hope it can be welded after getting in there good and sanding it down a bit. Really don’t want to try to recondition it…
  13. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Is the planetary the same as the Cam? Where the synthetic final drive oil goes? I do plan on draining and adding a couple ounces since tracks are off. If it is over full I guess that will be obvious since much more will come out than expected. Also, having absolutely no problems operating the bobcat, just noticed it was leaking after seeing the sight glass was low. Maybe I caught it early?
  14. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Went back and cleaned it up the best I could with it still connected to the machine. It’s very inconvenient as it’s out in the woods about 20 miles from my house.
    Anyhow, so the small leak is coming from a rusted chipped off area at a plug. Didn’t see the plug with all the grime.
    Not sure it would help replacing plug since the housing is chipped/rusted there. What are the thoughts of still welding it? I know the plug would not come off without grinding it, but no reason for that. Problem is I can’t get all the way around the plug so it would only be welded where the hole is. Will the leak still find a way out since I doubt the o-ring would survive the heat?
  15. Tones
    Tones Senior Member
    Mar 15, 2009
    2,105
    Ubique
    While I'm not familiar with your machine and only writing in general terms and having rebuilt a few drive hubs and motors. The plug you found could be the drain for the gearbox and welding it could make very difficult to be removed in the future. Checking the oil level of the gearbox will determine what the real problem is. Overfilled planetary gearbox can generate high pressure and will force oil out of the weakest point. I've had a shaft seal blow in towards the hydraulic motor, another blew out the Duo Cone seal and another blew out the seal on the faceplate. If the oil level is good then removing and replacing the plug would be a better fix.
    Depending on how bad the leak is checking the oil level should become part of your prestart checks until the repair is done.
  16. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    I know everything is probably rusted, but can you remove the lines and take the drive off?
  17. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Will be checking the oil level next weekend. Was just making a plan so I have the welder scheduled. Not thinking that is a great idea now. Ugh. Back to square one. Yea, I can try to take off the lines, but they are so rusted it is likely will need to replace all the 90 degree connections.
    What if I just JB weld that spot? No heat and it isn’t the drain plug. It does have a spring and a spool behind the plug, but can’t get it off anyhow so might as well keep it closed up. Is JB weld any good? Will it last?
    or just take it off and replace everything necessary. Ugh
  18. skata
    skata Senior Member
    May 10, 2007
    1,293
    midwest
    I don't know buddy. I feel for you though.
  19. Tones
    Tones Senior Member
    Mar 15, 2009
    2,105
    Ubique
    Im guessing that under the head of the plug there is an 0 ring seeing as it's part of a spool assembly. Could be getting easier and cheaper to fix all the time. :D
  20. mfiveash
    mfiveash Member
    Nov 14, 2021
    12
    Virginia
    Okay, ordered a $72 plug with $25 shipping. Now I have to see if I can remove this old one without causing more damage and hope the new plug doesn’t still leak. I will keep y’all updated. Thanks for all the help.
