ak_snowbear
CT332 Rexroth drive. The lock rig will only move 1/2" then stops hard. Note the white marks. I have put some heat to it but it didn't help.
Left to my own thinking my next thot is to put as much heat into it as I can. It's about 8" in diameter so it's pretty tough to get it glowing w/o heating everything else. Another idea I've got is to make a tool that will fit in the 4 slots and put the big air tools on it. As hard as it's tagging up I doubt I can make something strong enough. Worst case is break out the welder and run a bead around it. If I could find a replacement I'd probably jump right to that option.
Any ideas appreciated.
