MNagel
Hopefully someone might have a little insight in transmission diagnostics on a Fiat Allis FR-15 loader. It's a 1988 era machine. 4 speed Powershift, the lever shuttle with twist know to switch gears. Lever has been replaced earlier in its life. More often than not, in order it move, the machine needs to be placed in 3rd (or 4th) gear to get moving. Once moving at any speed, it will shift fine into both 1st and 2nd gear. Pressure is consistent on the gauge when put in any gear. Can watch the pressure drop slightly when shifting and goes right back up (both moving and sitting still). It seems the gear shift lever is functioning properly as you can watch the pressure fluctuate each time you switch a gear. It has all the power to the ground you would expect with a solid working transmission, just most of the time it will just sit and not take off in either 1st or 2nd gear from a dead stop. Occasionally it will take off in 1st or 2nd from a stop, and when it does, it is crisp and solid. Anyone happen to have any experience with this issue, or possible ideas from those with past experience on one of these older Fiats? I do have a service manual for the machine, however, the symptom/diagnose section is less than impressive. Greatly appreciate any thoughts. Thanks
