Fiat 10b liner installation
Discussion in 'Dozers' started by 02Dmax, Dec 17, 2014.
  1. 02Dmax
    02Dmax Senior Member
    Dec 5, 2007
    666
    MO
    A customer up the road calls me up and wants me to come look at the engine in their 10b. It blew the head gasket and come to find out they had put one in it about 30 hrs prior to this one failing. So I immediately thought they didn't get something clean or didn't torque it.
    So I go up there, the engine is already torn down. I start looking things over and asking questions. Gasket was blown on #5. So I get out my dial indicator and block to measure liner height. #5 is .005 lower than all the rest. So now I know what caused the failure.
    So my question is- I've never installed liners in one of these engines. I've heard that you use some kind of cement in the newer Iveco's but am unfamiliar with the procedure. Fiat mechanics are long gone from my area so I was hoping someone knew which direction to point me. I've attached a pic of the number I found on the block. The block has been counterbored and equal shims were installed under the liners.[​IMG]
  2. Queenslander
    Queenslander Senior Member
    Apr 5, 2009
    927
    02Dmax,
    I have a 14C which would have a similar motor to a 10B.
    Service manual doesn't seem to mention anything out of the ordinary.
    I would like to know how you get on removing the sump.
    This manual is for the FL14 trackloader, but on our dozer it appears it would be just as easy to completely remove the motor.
    I need to replace big end bearings.
    Cheers, Greg
    View attachment IMG_NEW.pdf
  3. dirthog
    dirthog Senior Member
    Jan 14, 2006
    358
    heavy equipment mechanic
    central pa
    The 10C had a OMCP3/100 Fiat engine in it and I beieve the liners need to be pressed in the honed. Have to see if I can find any of the manuals for that engine. Oh and the 14C has a 8205 different type of engine all together.
  4. 02Dmax
    Dec 5, 2007
    666
    MO
    I removed them by hand so these weren't pressed in.
  5. Andrew_D
    Andrew_D Senior Member
    Oct 20, 2012
    297
    Newdale, Manitoba, Canada
  6. 02Dmax
    Dec 5, 2007
    666
    MO
    Thanks! I'll try that.
