Yup I have to admit when I am WRONG..........I had this Wrong!
Now I know who you are GURU I am not supprised you have a GOOD GRIP on 793 Dumpies........
Here is some more just for GIGGLES:-
1. Does a Speed/Timing sensor measure Speed?
2. What is the function of N1 and N2 on a ICM Tranny?
3. What is the Redundant feature of a 3516 A still cast into the Block all the way up to C Engines?
4. What is the Design Flaw in a 793C Header Tank Assm.?
5. How many "Tractor Protection Valve's" does a 793C have?
6. Can you bench FLASH an ADEM II and configure it in Multi Torque? Why/Why Not?
7. How many different types of Piston Cooler Jets on a 3516?
8. How does a CDL use 2 Pieces of 16 Gauge Copper Wire to transmit information between ECM's.
9. Who casts Fan Hubs for CAT 793C?
10. How much HP does the Fan and Pump Drive suck on a 793C?
11. MYSTERY Question (I don't know the answer to) Why did CAT go to the effort of relocating the TC Out Speed Sensor to the Transfer Gear Housing. What is the advantage?
Do you have any 793F or 797F Trucks in your area yet?
OK, give it a go...
1. It measures Engine Rpm, (Frequency change) Camshaft Position (Square Wave change) and Direction of Rotation (Square wave pattern).
2. N1 and N2 are only used on 785-793 trucks. When the shift lever is in N, the trans is in N1. The pattern on the rotary spool is, N1, N2, R, 1, 2, 3, etc, as you rotate it around. The lever is R, N, 1, 2, 3 etc. So if your in N on the cane, then shift to R, the rotary spool clicks from N1 through N2, to R. Ok, so then when you shift from R on the Cane, you go through N to get to 1. So for this shift the rotary spool shifts from R back through N2 to N1. (This lines up with the N on the cane), then the trans goes N1, N2, R, to 1 position. Anyway the reason for all the shifting all over the place is to add a time delay between directional shifts. It helps the larger clutch packs of the bigger trucks to fully disengage before engaging the opposite direction clutches.
3. Have no idea... something to do with the woodward governers/ mechanical fuel passages maybe??
4. Cat don't have design flaws! lol
But interested in your answer
5. If you mean Pressure protection valves in the air system then the 793C has 2 factory fitted. One to separate the main air system from the secondary (back of the cab) and one on the ARC relay valve supply from the main air tank.
6. Yes you can bench flash a ADEM 2. It's dangerous to assume. As I haven't done it I don't know for sure. I would expect though that the ATY flash file is defaulted to the Multi torque setting, but in saying that, the eng ecm needs to talk with the trans through CDL for that config to work. If that comm's don't happen, the ENG ecm will stay in the 2160hp mode (dual Hp config) Interesting to hear your thoughts.
7. Don't know??
8. It uses a SAE standard communications protocol. Putting a scope on it you can see the signals as a square wave blip.
9. Cat? somewhere in mexico is expect
10. About 130HP
11. I believe it cleans up the COS signal. Cleaner signal = more accurate speed reading leading to the xmsn being able to calculate trans shift time a little more accurately. Not 100% on that though.
Yeah we have several fleets of 793F's running around. 3 moving dirt. 2 more getting commissioned as we speak plus a HEAP more on order. The first 797F's are on the boat. Due here in nov. They are wanting 3 of them onsite before the transport curfew over xmas. See how they go. They are a nice truck. the C175 is a nice bit of gear.
