No kidding spud, you are a lean mean building machine. I suggest you save all the higher risk stuff for when someone else is home.
That would leave me only 2 days a week to work lol. I rather get the fall protection system with lanyard, it's only $160 from 3M made for welders. I can always either cut my way out or climb back up the way I fell, I do have the strength to grab a rope pull myself upside down and clamber back up upside down.No kidding spud, you are a lean mean building machine. I suggest you save all the higher risk stuff for when someone else is home.
If you tie off to a truck, make sure you take the keys.@aighead I go over the roof to the ground on the other side. ^ It is not osha approved but if you can restrain yourself to begin with, you are ahead of most home users.
Go watch a roofing crew in town and see how they do it.
you go up in the morning and hang a retractable on those and then pull the retractable down to the top of the ladder. then you can hook on and climb up on the roof safely.
I was looking for some screws at the shop, and I found the bag of screws and instructions for that Werner anchor pictured above. It is a small world.https://www.homedepot.com/p/UpGear-by-Werner-Temporary-Roof-Anchor-A210402/203907999
I've seen these used quite a bit. Its just two steel plates and a D ring. Go up to the ridge and screw it down, then re cap the spot or tar the holes. $33.00 is lots cheaper than falling.
