steevz
The truck was running fine. It was driven for a delivery first thing in the morning, left it idle back at the shop. About 15 minutes later, it was moved and turned off.
Later in the afternoon, the truck wouldn't start. At first I thought it was the intake heater, because the "Wait to Start" light was not coming on, and it say for approximately 6 hours. This is bizarre, because the truck did not die. It was physically turned off, and will not restart.
In-line fuse at the battery has voltage for the ECM. When cranking there is no smoke, the plug going into the HPOP is not getting voltage while cranking. The intake heater relay is not getting ground when turned on. Not getting a Check Engine light OR Wait to Start light when the key is first turned for a couple seconds.
All signs look like they're pointing to the ECM not getting power. I don't know if there are any more hidden fuses to power the ECM. Both the plugs going into it are tight. I'm running out of ideas and would love it if someone could chime in. Ignition? Fuses? Relay?
