So I have a 2007 f650 ford service truck with a c7 cat with 22000 hrs on it. Motor is wore out and has been over heated a couple of times. It has wax63710 motor in it. I have found a unused military surplus motor for it fmm12803. It is set up for 24volt. Was wondering if the ecm will work with 12 volt and if all sensors and injectors will work with 12 volts system or if would have to change out sensors and ecm and injectors with old motor
