RenoHuskerDu
This 1999 F550 was a bucket truck servicing grain silos in Iowa farm country. I stripped the bucket, rack, then the bed yesterday. Lotsa work. After getting all in shape, I'm putting a flatbed on it to tow heavy gooseneck.
I power washed it today and now I have a clean stripped chassis cab, but there's been some welding on the frame that I can't figure out.
Looks like a 24" section was added. But frame length is standard, 80" cab to axle. Just like the tool bed I took off.
It looks like a cross member for center support was added. There's a carrier bearing on the driveshaft in that added section. It doesn't look stock to me. Check out how the cross member has been welded in the middle, and the carrier bearing support looks like chunks of stock. Weird.
Or maybe the frame got bent there and it was repaired. The welds use heavy gusseting on the inside, looks like a pro did it.
Maybe one of you guys has an F550 99-03 and can shed some light.
