Hello,
I have a question, might should be in the mining and aggregates forum, but does not only apply to mining and I wanted to get the best chance for everybody to see it.
I have been studying some material and test running some different areas of a pit. The material is rock, specifically rhyolite, which is best defined as the volcanic equivalent of granite. We have crushed and sold some of this material for smaller projects and some to highway department. Since studying and what not I have made some observations. Very hard material, 25k to 49k psi breaking strength, 70% silica content, very abrasive, and absorption level is a little high. But also breaks pretty flat and englongated. This would be the area I am questioning.
I know that cone Crushers are typically bad for producing f and e. This rock seems to tend to be f and e. Maybe the two together is making the f and e problem worse. If you speed a cone crusher up, i am told that will cut down the f and e, but test cone is a jci k400, which is a high speed cone. I talked to the factory and spinning it faster Would def reduce wear life and bearing life, and not to mention the higher probability of a come a part, which ain't easy to fix. Been there already.
I hear that horizontal impact would break things more square, but wear life sucks, and we are already hardcore abrasive. Professional opinions from some of my suppliers says that we would kill an hsi. I have never been around one myself, but I trust my suppliers opinions to some merit or their profession.
Does anybody here have any further opinions or advise? The product coming out now is stellar, and also accepted by customers, those needing a spec even made a new spec because it passes easy on 5:1, but we would like to achieve 3:1.
