Framer
If a machine that does not require ballast were equipped with foam filled tires how much more could it lift at distance? How much more stable would it be. Looking at buying a second machine. Don't usually lift much more than a couple thousand pounds at a time so would like to know how much the actual tipping load would be at distance. Would these tires enable you to damage your boom more easily? Maybe a 6000 lb machine would do instead a 9000. 6000 just seems small for a jib, or a 18x18 2x6 framed wall with plywood and a box out. Which machine is the most under or over rated in what it will actually lift. Is a 6000lb machine big enough for framing a house including trusses? Never really been on one.:canada Thank you.
