abdul k
Hi All,
I need the part number for the HYDRAULIC SOLENOID VALVE that provides the control for the knuckle (offset) boom cylinder. The block has three ports and the valve has a STERLING coil that activates it. The valve has seized up and so is the coil which came off with great difficulty and in the process the insulation has torn out and exposed the copper coil. I cannot see a part number for the coil either except for the:
STERLING HYDRAULICS, 12VDC 18W
CAS 012D
PAT _ _ _ _
MADE IN USA.
The machine is a HITACHI EX50URG with a ISUZU 3AD1 TURBO charged 3 cyl engine.
Would any one know the part number for this valve and coil, your information will be greatly appreciated.
thanks
Abdul.:beatsme
CAS 012D
PAT _ _ _ _
MADE IN USA.
thanks
Abdul.:beatsme
