Ex200 5 swing down to half speed
Volvomad
Ireland
The machine only seems to be swinging on one pump only even when no other movements are performed .
Tracking is a bit to one side also . All digging functions work good , maybe a little slower than normal but not bad .
Volvomad
Ireland
I found out it should only ever swings off 1 pump . I checked main rear pump pressure and had plenty pressure stalling the swing with the bucked down . I then checked the pilot pressure to that pump and swinging would not rise the pilot pressure above base pressure , like other functions would . I then switched electric plugs on the 2 pump servo valves (not sure what they are called) and bobs your uncle . I did not check if the sluggish track switched sides as it dont matter for the minute and my crowd may be a tad slower but a big improvement over all . I will revisit the issue when i get time in a week or 10 . I am thinking servo pressure switches behind cab ,ECU or wiring .
