I have a 200-3 and installed the conversion kit as the instructions told me to, as best I could figure, (really bad instructions) and when I started the machine it will slow idle only under max load, move any valve and it stalls. I took out the spring on top of the new control piston and engine runs fine but got slow power, I then put the spring back in and still only have slow power, tracks will only go in slowest speed whatever speed I select. After I took the spring out and tried it the piston that is above the spring came out, I slid it back up in with the spring back in but it does not go to full load like before I tried it with the spring out, something changed when I tried it with the spring removed. anyone know what might be going on here? Opening track valves should call for more pump stroke but it doesn't.
