jefftchase
Hi,
I have been tinkering with a ex-120-2 for a year now. It was leaky and uncared for. I been fixing the leaks, but shortly after buying last year the hydraulics went out (it was real jerky and would stall when I would steer hard right before it all went out). Anyways I replaced the dp sensor, angle sensor, filters, center joint seals (leaky), and swing reduction seals (leaky). Still need to do oil cooler and stick cylinder. I check the solenoids on the top of the pump too, seem to be working. If the machine was cold it would allow me to move the boom and swing for a minute or two, but after it warmed up it would barely move. And now when I drop the safetly lever the machine total stalls out. My ecm and pvc are blinking red. I checked all the fuses.
Anyway I order cable off ebay and it came with dr zx with a palm pilot emulator for a pc, but it will not connect to the machine. Does someone have dr ex pc version they can share or any other tips so I can read the machine.
I got the machine to limp along by taking the plate of the bottom of the pump and flipping it and putting it back in, so I think the pump is ok.
I am at the point were i either by pass the electrical systems (rather not) or start replacing wiring I guess.
All I want to do is dig a pond,
Jeff
Jeff
